cutting
I updated and installed plug in and Im not able to cut I have silhouette sd message says sending data can some one help me fix this before the update it was cutting.
    One thing to check is if Sil Studio is open. It is known to keep MTC! from working.
    I agree with Mars - sounds like you had Silhouette's program open as well. If you have both programs open, the Silhouette program takes control of the cutter and then MTC cannot "access" it to cut and this is typically what then happens. Make sure the silhouette program is closed, then try again from MTC.
