Making brass jewelry
crjwilsoncrjwilson Member Posts: 2
edited December 2014 in Off Topic
I am needing some help. I make brass and nickel jewelry and when I first started the brass and nickel would not burn and now it is burning the nickel. Can someone help me with what can can i do to stop it from burning. Thank you.
  • Liz_ALiz_A Member Posts: 9,796
    @crjwilson‌ - Welcome to the Make The Cut! forum, a place where you can get information on electronic die cutting machines that are supported by the software Make The Cut!. It sounds like you need a jewelry making forum, as I have no idea what you would be doing with an electronic die cutting machine that would burn nickel (which has a melting point of 1,555°C (2,831°F)).
    Post edited by Liz_A on
