copy/paste from one project to another??
mom6hsrmom6hsr Member Posts: 277
edited December 2009 in Help for Make The Cut
I have two projects open. I want to copy a design from one to another. When I do this, it 'paste' the design, but its not the same size I had on the first page. And, I kinda want it to position itself on mat #2 exactly where it was on mat #1.
Is this possible? shortcut I am missing?
  • mom6hsrmom6hsr Member Posts: 277
    oh, I know to change the properties in location and size, that is what I am doing now. but, any shortcuts for this, or can you build it into the sofware?
  • I also do what mom6hsr does and just change to size and with properties so it is the same size as the orginal.
    Mary
    When you paste, it uses the size of the Caret as it's height. I will add a new type of paste called "Paste In Place" in the next version that should fix the issue...
    oh, thank you!!
    To give you another reason for this use: When making word books, you can make page after page by just putting down the original square/rectangle, then adding a design per page, then dragging the square/rectangle righthand side til you get to the design, so that the design overlaps the square/rectangle. OH, and having the design "paste" on the new mat EXACTLY where it is on the 1st mat, helps in lining up items, such as a word book.
    Just in case your wife has not made one yet, here are a bunch on this site:
    http://mycricutscrapbooking.com/tag/word-book/
