New Software! Popup Card Studio v1.0!
edited January 2014 in General
Hi Everyone!
Hello CHA 2014!
We have released a new product! After months of hard work, Popup Card Studio has been released.
Create Unique Popup Cards in Minutes... not hours! Bring your cards in to the 3rd dimension! Create popup cards and origamic architecture (otherwise known as Kirigami) in no time. With Popup Card Studio™ you will be able to create and edit in three dimensions allowing you to get a visual representation of your project that is as close to life as possible.
Popup Card Studio™ will allow you to export in SVG, PDF and 3DS formats along with sending directly to your cutting machine (such as the KNK Zing™). There are so many editing features that you will be able to do almost all your work right inside Popup Card Studio™.
Features:
Simple, Yet Powerful - We took all the best features of Make The Cut! and added them to Popup Card Studio™. Split, Layer, Join, Weld, Boolean Join, etc. are all there making it a familiar interface.
Works With Make The Cut! and Inkscape - If you have Make The Cut!™ and/or Inkscape™ installed, you can copy and paste SVG data to and from it.
Send Directly To Your Cutting Machine - If you have Make The Cut! installed with the plug-in to your machine, Popup Card Studio™ will allow you to send the cutting data directly to your machine
Mountain, Valley and Hinge Lines - Popup Card Studio™ separates three specific fold lines from the cut lines. You can specifiy how fold lines look as well as how the cut lines work
One Piece Of Paper Is All You'll Need - All cards created with Popup Card Studio™ will only need one piece of paper. No gluing, either. Simply design, cut then fold!
Import SVG Files - It's fun to see a two dimensional graphic turn in to a three dimensional object. You can import all your SVG vector graphics. Retains layers and colors as well
Work In Three Dimensions - Popup Card Studio™ allows you to work in three dimensions giving you full control of how layers should work... even with transparency
Watch How It Folds - Popup Card Studio™ allows you to fold the card from 1 degree up to 179 degrees. You can also work on the card when it's folded at any degree
Virtual Snapshot - Powered by POV-Ray, Virtual Snapshot gives you the power of ray-tracing without the complication. This feature will allow you to see what your card will look like in real life without having to cut it out first
Customizable Interface - Popup Card Studio's interface is customizable. You can move toolbars where you neeed them and even change the color of the interface
A User-Contributed Online Gallery - Comming Soon: As soon as we have enough user-contributed SVGs and Cards, we will allow all users to download and use them in their own projects
Powered by OpenGL™ - Popup Card Studio™ is powered by the industry standard OpenGL. A majority of video cards, old and new, will be able to handle OpenGL without driver updates
Full Printer Support - You can print directly to your printer (mirrored or otherwise) with your lines color coded based on fold or cut
Created By Crafters - Popup Card Studio™ was created by crafters. Just like you, we are do-it-yourself kind of people. We have been heavily involved in the crafting industry for the past 4 years. We understand how crafters think and how they work
FOR A LIMITED TIME
Make The Cut! Customers can get 15% off by using their Registration Code from MTC as a coupon code in the order form.
To get your registration code:
Option 1: Go to the Lost Registration Key page and have it sent to you via email, then copy and paste it in to the order form.
Option 2: Open Make The Cut!, then go to Help >> Advanced >> Unregister Make The Cut! This will copy your registration code to your clipboard. Then simply go to Help >> Register and paste it back in.
Option 3: Find the email you recieved when you purchased Make The Cut! and copy and paste the code from there.
Option 4: If all else fails. You may use the Support section of our site and we will help you find your code.
INTRODUCTION VIDEO TUTORIALS
Susan Blue Robot has put together wonderful tutorial videos for you to watch and get familiar with Popup Card Studio. You can learn more by going here: http://www.susanbluerobot.com/
CHECK OUT POPUP CARD STUDIO
Click here to go to Popup Card Studio's website: http://www.popupcardstudio.com/
«134
