cutting with the 60 degree rolland blade in the cricut [Mother/Daughter Silhouette]
KATHYANNKATHYANN Member Posts: 1,428
edited May 2010 in Resolved Issues
Is there a trick to it? I am trying to cut this out in a textured cardstock and it looks crappy Looks like I sawed it out with a rusty knife. I have reset my settings 2 speed 4 pressure 5 blade + 2 speed 5 pressure 6 blade. both the same awful look. Is it maybe the design? I have turned the white sash, bow, cuffs, & Collar to black so it is a basic silhouette...... should I try different paper?
Kathy - Katiedoodlesgran
  • waterrabbitwaterrabbit Member Posts: 2,217
    Okay, here's my advice. Take what you want from it -
    1. Try using an untextured paper. Textured papers are the enemy when doing a delicate cut like this. I like to use something nice and crisp - and a solid color all the way through if possible. K&Co type papers seems to work well for me as do the glossier prints from DCWV and their shimmer cardstock that's smooth.
    2. Try raising your blade to a 4, keeping the speed at 2 or 3 and the pressure at 4 or 5 and do a multicut of 2. Sometimes we've got the blade too low so the sharp part isn't hitting the paper - the unsharp part ABOVE it is.
    3. If you really want the white areas, use the layer function to separate them up from the bottom. Arrange the layers so that those details are on the BOTTOM layer and will be the first to cut. The paper, being a solid, is most stable at that point. If you try to cut details out of the outline shape later, it just leads to frustration.
    4. And always make sure your blade housing is clean and the blade is clear of any obstructions.
    I don't know but can you share the file? I love that.LOL
  • KATHYANNKATHYANN Member Posts: 1,428
    edited May 2010
    I believe so, I was going to share the cut file I just wanted to make sure it cut ok first. My Hubby brought me home 10 dvds with click art on them I believe they are royalty free they are advertised as free on the site. I just tried cutting it with regular cardstock and it cut beautifully so I will share the cut file in the gallery under mother & daughter in Family category.
    Kathyann took the image you posted into inkscape and it was pretty jagged around the edges I do have it cleanned and have cut it using 60 degree blade on 5 and high presure and a heavy card stock if you want the one I cleaned then I'll post it
    image image image Rachellann uses the Black Cat Cougar, Gazelle, Expression, and 34 inch MH871 vinyl cutter http://www.thymegraphics.co.uk/index.asp http://www.thatsscrapinc.com/ My Blog is: http://rachellsmanycrafts.blogspot.com/
    I would like to have if wither of you wants to post or email me! Adorable.
    This is what I got using MTC and changing cardstock. http://i35.photobucket.com/albums/d183/katiedoodlesgran/cards/IMG_8257-1.jpg
    I think the textured cardstock is more spongy the plain is crisper so it cuts nicer. JMHO
    Christy and Ruth I sent you both an email. I imported the cut design to the MTC gallery
    Thanks Kathyann!! Your final work looks fantastic!
    humm, I didn't get no email but thank you for trying.LOL
    Rachell, yours looks great as well!!!!!!!!
    edited May 2010
    here I will try this and see if I can attach the file here. I tried to put it in the gallery but am unable to gain access for some reason..... Yes Rachaelann yours looks great. I just havent messed with inkscape in so long I forgot how to edit nodes. But MTC did take out the worst of the shay lines in the image for me Thank goodness.
    TADA LOL :-} I dont know why I didnt try that to begin with. I always make things harder than they need to be. :-}
