Cameo Can't Connect!!
carolinagirlcarolinagirl Member Posts: 2
edited October 2012 in Help for Make The Cut
I have a Cameo only a week old am cutting with MTC every other page I sent to cut says can't connect. I have the unplug from computer and replug in, then it connects. I have tried new cord no difference. I called silhouette, they think it could be a MTC issue but know nothing about it. I have no idea and none of my friends have this issue can anyone help. I have only cut in MTC and to be honest have no idea how to cut in silhouette. Thanks for ANY HELP!!!!
    Do you have any other design programs open? If Silhouette Studio is open, it will 'claim' the USB port and MTC won't be able to connect. Same thing happens with other design programs...
  • Cynthia BarberCynthia Barber Member Posts: 227
    It happens occasionally to me, I just turn the Cameo off and turn it back on and it works.
  • carolinagirlcarolinagirl Member Posts: 2
    I do not have any other design programs open at the same time and I would not mind if it was occasional but it is happening with almost every other cut , if you have any other ideas they are much appreciated!!! Thanks
    I'm not sure. :-?
    Any Cameo owners out there with an answer? :-??
    @juliefes, do you have a Cameo?
  • MeFlickMeFlick Member Posts: 9,097
    I have a Cameo only a week old . . . I have only cut in MTC and to be honest have no idea how to cut in silhouette. Thanks for ANY HELP!!!!
    First, since you say you have only cut in MTC and that you have no idea how to cut in Silhouette, have you INSTALLED the Silhouette Studio software that came with your machine? Opened that software and had it find your cutter? If not, you may need to do so as there may be drivers and such that are installed to your computer that are needed to communicate with the Cameo.
    Also, you don't say what operating system software you are running on your computer. Is it windows 7? Windows 7 can cause problems in installing drivers and working with usb ports I gather so that could also be causing you some problems.
