printing
pezadoodlepezadoodle Member Posts: 53
edited December 2009 in Help for Make The Cut
i still cannot make mine print....any thoughts? i turned off machine, turned it on, put in a cart, hit the refresh button.......same error box keeps popping up...perhaps i have a real error..??
    Hello!
    Could you tell me the first line of the white box in the cutting dialog? The one that says "Connected to Cricut [v2.32.20]" If it says "v-1,-1,-1" you will have to update your Cricut's Firmware. It's free to do. There is more information on the FAQ on make-the-cut.com
    Also you may have to run it in a different compatibility try one down so if your running vista try it in XP mode
    image Follow Me on Pinterest
