how to properly save svg's
susan_ID2293susan_ID2293 Member Posts: 2,919
edited December 2009 in General
What is the proper way to save files a svg's? The files I saved as MTC files open again fine, but those I saved as Svg's get an error message :
Couldn't import SVG file
XLM engine failed to parse XML file
Not sure what that means.
    How are you saving SVGs?
    The proper way to save is:
    Click the shape you want to save so it has a red outline around it
    Click the "Edit" menu item, select "Export" then "To SVG"
    That should do it!
