I have posted a new tutorial on how to design a horseshoe, along with the cutting file for it, as well as the cutting file for the Shamrock Popup Card. The technique used for creating the Shamrock card is the same as that used for creating the Heart Popup Card demonstrated during the February 14 Q&A Webinar, except for the original shape used.
You will find the tutorial called II.19_Make a Horseshoe posted at the bottom of the Basic Lessons folder in the Files section at the MTC_Tuts Yahoo group
http://groups.yahoo.com/group/MTC_Tuts/files/02_Basic Lessons/The Horseshoe_JF.mtc and ShamrockPopupCard_JF.mtc cutting files are in the Shared MTC Files folder of the Files section
http://groups.yahoo.com/group/MTC_Tuts/files/Shared MTC Files/You need to be a member of the group in order to access these and all the other files, tutorials, photos, and links posted at this group. Membership is free. You can join with the Web option only, if you prefer not to receive group e-mail.
1 • •
1. Basic Shapes
2. Resizing proportionally and non-proportionally using the Selection Properties toolbar.
3. Shadow Layers
4. Selecting images-Select, Rotate, Distortion
5. Joining
6. Splitting
7. Erasing
8. Welding
9. Duplicating
10. Wrap Object to Path
11. Rotating
12. Layer Properties – Add, Remove, Move, Show, Hide
13. Adding Color
14. Add Text
15. Add Fonts temporarily or permanently
16. Kerning text
17. Bezier Warp
18. Rotate 90 Degrees
19. Flip
20. Mirror
21. Cut by layer.
It is so much more fun to learn in the process of doing a project. Give it a try!
Free MTC Tutorials:
