Trying to design a file HELP
I'm trying to design a robot valentine that I saw online. It uses a mini Hershey for the body and I don't know what size they are. Also I would like for someone to check the file to see how it can be improved. I will try to attach the original picture and my file but if it doesn't show up I will need help. TIA
mtc
mtc
robot vtine.mtc
4K
350 x 509 - 40K
    My files said they attached but they aren't there.
    OK worked this time.
    350 x 509 - 40K
    mtc
    mtc
    robot vtine.mtc
    4K
    Post edited by salleys on
    For the mini Hershey bars, I make the labels 1.25 inches wide by 3 inches tall.
    Starting at the bottom, I draw temporary guide lines at these positions: 3/4", 1-1/8", 1-7/8", and 2-1/4". The space up to the 3/4" mark is on the back (plain). The space between the two bold marks is the first slanted side. The space between the italics marks it the other slanted side. The space between the two slanted sides is 3/4" for your main messge or picture. And of course the remaining 3/4" at the top goes to the back.
    Draw a little sketch of the 1.25" x 3" label, then cut it out and try it on your little Hershey bar to see how it fits. That might make it clear
    Found this on google......try one and adjust from there, your Robot is adorable.
    K_lee's Krafting Niche'
KNK Zing with Make The Cut!
