I uninstalled my version and reinstalled with the CD that came with my Cameo - which is 2.0
When I click to see which version I'm running in Sil Studio, it says 2.0.0d
If I open a Studio file and try to "Save As," in the first box I will type box.SVG, but the bottom dropdown still gives me no other option besides .studio, so my file saves as box.SVG.studio
If I go to MTC and try to pull it in, when I go to import the SVG, the ones I saved from Studio do not appear, and at the bottom where it says "file type" in that window, it gives me no other option than SVG - there's not an "All Files" option.
I'm getting really frustrated!!!
http://www.papyrusjungle.com
http://www.mainstreetartsandcrafts.com
http://papyrusjungle.blogspot.com/
By that I mean file folder in My Documents.
Blog: http://michellemybellescreations.blogspot.com/
I Create For:: http://www.scrappydew.com/
MTC Challenge Committee
1. Open a library file in SilStudio
2. From the menu choose File, the SaveAs
3. Navigate to a folder other than the default studio folder (the folder I choose is 1 MTC Project Files on my pc)
4. In the filename box type "testfile.svg" and click OK
Then in MTC choose import svg and go to that same folder to find the file.
Is your Sil Version 2.0.0d
When I go to import from MTC, I cant see the cake.svg file at all.
frustrated is the nice word for how I'm feeling right now. I usually don't have any trouble with things like this. Grrrrr......
I'm sure that's the issue, but I just have to know how to fix it.
Free MTC Tutorials:
http://groups.yahoo.com/group/MTC_Tuts/
It keeps saving as filename.SVG.studio and then won't show up as an SVG when I try to import.
Then I put the CD back in and reinstalled, and it recognized it as designer edition and still had my libraries intact.
Free MTC Tutorials:
Free MTC Tutorials:
I am hoping someone understand what I am saying.
I did not try 1.9 - maybe I'll give that a shot when I get home later tonight.
Free MTC Tutorials:
Free MTC Tutorials:
This is the version I'm running and it works. I say go down a version. I initially installed using the disk that came with the machine, then upgraded to designer.
http://krapikreate.wordpress.com/
Cutting with 24" KNK Maxx, Silhouette SD, Expression, Cameo, and Zing
Team KNK Designer
When I installed from the CD, I installed it to a folder called Silhouette Studio 20 . (I created the folder myself in windows (under the Programs folder - before installing the software). I did this as I had version 1.7 on my computer and did not want to mix the 2. Also it took 3 tries before my unlock code actually worked.
I've attached the screen showing the version
When I installed the 2.0 from the Cameo disk, I actually did an uninstall first and then re-installed it.
My screen version looks exactly like yours, Susan.
Cutting with 18" Cougar, Silhouette SD and yes, I still have one of those "other" machines too!
Valerie
craftyladyvalerie what version of windows are you running?. I am running windows 7.
