How do I import from MTC gallery?
I am experimenting with the program and I can't find a way to get the gallery images onto the mat. I can view them on a virtual mat but I cant get any further. I am very new to this and just trying to find out what it can do.
    Help > Free SVGs And MTC Files
    Gallery Screen Will Pop Up
    Click On Decending To View Newest To Oldest
    You "Must Hit "Search"
    The Images Will Appear (Choose The One You Want.
    Click On Download
    The Save Screen Will Appear Take Note Of Where The File Will Be Saved
    Type In a File Name Then HIT SAVE
    425 x 360 - 39K
    226 x 296 - 22K
    439 x 374 - 49K
    Post edited by Berryone on
  • Hi,
    I have the lastest v. of MTC and when i click download the download box isnt coming up HELP please
    What Image Are You Trying To DownLoad?
  • it doesnt matter what image i click on it never comes up. i have purchased the program and am able to use my own SVG files or other i have got of the internet
    Hello Berryone-I still have the same problem as thestinkbug. I still am trying to get a download from the Gallery. Specifically the Willow tree girl. It doesn't matter what I try to download, though. I get to the part to click on download, and no download window. Still can't figure out why. Anyone else have this going on other than thestinkbug and I?
    @aubrey - I just did a search on "willow" and there were three that came up in the search window. I clicked on all three, and was able to get all three. Two of them ask you to name a file first and then automatically opens the files, the other one is placed directly on the virtual mat. I forget which is which, but that just means that two are in .svg or .mtc format and the other one is either .svg or .mtc. If they were the same files you were looking at, I had no problem retrieving the files.
    Aspire to Inspire before You Expire.
    North Central Idaho - cutting with a Black Cat Cougar
    I am having the same problem. When I click on download nothing happens, I was always able to do this before I updated to the latest version. Wondering if it is a bug somewhere? Andy?????????? :-h
    What Version Of Explorer Do You Have?
    Rather Than Saying "Latest Version" What Is The Version Number Of MTC?
    Help > About MTC
    300 x 307 - 31K
    @SBryanW
    This Has Gone Viral.
    There are no bugs on the gallery code as far as I know. There are a couple of possibilities. For the people having problems, make sure you have Internet Explorer (IE) 7.0 or later and make sure the MTC!.exe is not blocked by a firewall. There has also been some problems with the company that hosts the servers used - so that may be causing intermittent problems.
    To clarify what HappyCrafter was explaining, the images in the gallery that have a mat design behind them are MTC files, and when you click on "Download" it will ask you to save the file first. The images that have a light gray and white checkered background are SVG files, and when you click on "Download" they will be loaded on your mat directly, located where your caret is currently sitting.
    Thanks, Bryan
    Thank you very much Bryan for clarifying. I never bothered to remember which was which.
    @Berryone, I have IE 8 and MTC version 4.1.0. When I click on download nothing happens. It works sometimes with the older files, not sure maybe it is a server problem as Bryan suggested.
    thanks, "Um"
  • 1.4.0 is my v. that i have on my windows laptop. I have tried making MTC an exception for my firewalls and turning them off completely. Still when i click on any image being SVG or MTC files through the library the download box does not come up... I would really like to start using this for its full potential but have been limited to what i can find off the internet. PLEASE HELP
  • umbuggin2 said:
    @Berryone,
    How do I check to see if is is blocked? TIA ;;)
    "Um"
    If you have windows go to 'control panel' then 'network and internet connects' then 'windows firewall'
    Since you are using a really old version of MTC, 1.4.0 you may not be able to download a lot of the files if they were created with a newer version of MTC then the one that you have (which I venture to say a lot of them were).
    I'll get @SBryanW to come visit this thread again and give better insight!
    image Visit my Blog: http://melaniescrafting.blogspot.com/
    Cutting with 18" Cougar, Silhouette SD and yes, I still have one of those "other" machines too!
    Unfortunately, I don't have any more insight than what I suggested already (IE version and unblocking MTC!.exe in the firewall - make sure you don't have more than one firewall running). @thestingbug1985 - do you get an error when you click on the download link? Can you take a screen shot of what comes up on your screen right before you would click on download? Also, Berryone, who has over 2000 shapes on the gallery, has been sharing his files here on the forum - look for recent threads that start with "Files", e.g. the thread "Files 4 (05.16.2012) (May 16th 2012)" has 26 mtc files available.
    I only just brought this MTC like a couple of months ago so how can it be old????
  • http://forum.make-the-cut.com/profile/SBryanW
    When i download it just flashes, only once has the windows error thing come but but most of the time it flashes with nothing if that makes sense... I am usually a MAC user but have brought an older laptop so i can use MTC, as i liked it better then the other software out their but its just not working for me at the moment :(
    @thestinkbug1985,
    If you bought this just a few months ago, is your version actually 4.1.0? You told us it was 1.4.0 which is an extremely old version from about the birth of MTC around two years ago... It can be easy to get mixed up with the version numbers accidentally (I can never get amounts or time numbers correct--they get all jumbled in my brain).
    When you open MTC, click on the 'Help' tab, scroll down to the bottom option: "About Make-the-Cut!" and click on that, you should see the version number and your registered email address in a pop-up window. If you could double-check on that MTC version number, that would help us know what advice to help you with... Also, if your name and email aren't showing up on that information Window, there is a problem with your registration, which could also lead to problems downloading from the Gallery (as does not having Internet Explorer updated on your computer to a MINIMUM of IE7--no matter what browser you happen to use, the Gallery won't work properly if your IE is not updated).
    Dear PC,
    "For twenty-three years I've been dying to tell you what I thought of you! And now... well, being a Christian woman, I can't say it!”
    Auntie Em
    *Thanks for the extra quote in my siggy Shannon_Corbin!
    Jeanette in Orange County, CA
    Love my Italian Greyhound --> I.G.--> iggy
    Own a Create: Krikee, getting used to a Black Cat Cougar: Bagheera
    @thestinkbug1985 - I just replied to your support ticket. Please respond back to it with the answers to the questions I asked.
KNK Zing with Make The Cut!
