I haven't been happy with the Silhouette mats in my SD so I decided to try using transfer tape (R-Tape Clear Choice) instead. I have an 8-1/2 inch roll of tape so it fits 8-1/2 x 11 paper and I just trim the leading edge flush. So far I am getting good results. I can cut through card stock cleanly without cutting through the tape. I can get the registration marks to read automatically. I can get the cut off of the tape without it curling. I can keep reloading the paper/tape combo until all of the paper is cut and I can reuse the tape at least once, maybe more. I can prepare as many pages as I want ahead of time and have them ready to load back to back. I'm thinking my tape mats would be really useful for some other things, too, like cutting from small scraps and cutting extra long paper. If you have some of this tape you might want to give it a try and see if this will work with your cutter.
This is an interesting idea. But I'm not sure I understand the comment about reloading the paper until it's all cut? Do you mean that you're printing all the images on the paper once, putting it on the tape then cutting each image from that paper one at a time? Or are you printing ONE image on the paper, then sending the paper back through the printer to print a different image later?
Good question, Mitzy. That comment refers to just cutting, not print and cut. So for instance, I load up a red piece of cardstock and only cut one of two things. Then I keep that sheet on hand for when I need red next time. You could use it for cutting print and cut images one at a time, but I'm not sure what the application for that would be.
I have wondered in the past if it would work as a way to add stiffness and thickness for fabric but had not got around to trying it out. This post gives me hope. Great idea!
Sounds like a good idea but I'm thinking what I call transfer tape is only sticky on one side. So how do you stick it to the mat? Or is the tape you use double sided?
Jules, I understood it that the transfer tape serves as the carrier sheet itself, and no actual mat is used. But maybe I have the wrong end of the stick?
I bought a roll of non clear transfer tape by mistake, this would be a good use for it. I had only been using it for black vinyl (you can see the black through it a little)
I am using a roll of R-tape Clear Choice medium tack but any commercial transfer tape should work. The clear is stiffer than the non-clear but for card stock it shouldn't matter. If you are trying to use a transfer tape alternative @Jules, then the question is if the adhesive will come cleanly off the card stock without damaging it when you pull the cuts off the mat.
Carmen
My hubby's got a huge roll of clear adhesive film that I use as tranfer tape and I'm wondering if that sounds similar?
Is the tape that you use "medium tack"?
Thanks
