Blade offset question for KNK Maxx
cbauer50cbauer50 Posts: 173Member
I see a lot of discussion about blade offset settings for red-cap & blue-cap blades when using the Zing.
Do we use these same blade offset settings for the KNK Maxx - or are they just for the Zing?
Thanks.
Carol Bauer
Designs Sew Fine
http://DesignsSewFine.com
Agree Like LOL
  • Tiny_CutterTiny_Cutter Posts: 328Member
    Well it depends on the blades. If you are talking about zing blades, they use zing blade offsets
    -Mike
    Agree Like LOL
  • cbauer50cbauer50 Posts: 173Member
    no - not zing blades - I use roland blades in my KNK maxx - from what I understand - the zing blade holder does not even fit in the KNK maxx.
    Carol Bauer
    Designs Sew Fine
    Agree Like LOL
  • PaperthreadsPaperthreads Posts: 747Member
    The zing blade holder fits fine in the knk maxx.
    www.paperthreadsblog.com
    Pre-Order the Silhouette Portrait Today!
    If there are typing errors, blame it on my fat fingers on my mobile device....some days they seem fatter then others!
    Agree Like LOL
  • debzdebz Posts: 3,154Member
    I never change it on my Maxx. But I mostly use the red blade
    Deb
    http://krapikreate.wordpress.com/
    Cutting with 24" KNK Maxx, Silhouette SD, Expression, Cameo, and Zing
    Team KNK Designer
    Agree Like LOL
    well - I guess that still doesn't answer my question. If I use the blue blade, should I change the offset?
    Carol Bauer
    Designs Sew Fine
    Agree Like LOL
  • neldanelda Posts: 11,629Moderator
    I think this would be a question for Sandy or Chad. Try adding her name like this @SandyMcC to get her attention. Or email her directly.
    In Indy, blogging along at http://papercraftingwithnelda.blogspot.com/
    Agree Like LOL
    60 should be .40 offset and the 45 should be .25
    Those are the standard offsets for Roland blades.
    -Mike
    Agree Like LOL
    Thanks, Mike.
    Agree Like LOL
  • SandyMcCSandyMcC Posts: 3,161Member
    If you are using the blue blade purchased from KNK USA, then it will use the same Offset as the red blade purchased from KNK USA. You'll notice that the tip of the blue blade is cut back so that it will have the same tip location as the red one. That most likely will not be true of any Roland blades you purchase from EBay. I don't know what offset would work well for those. You'll probably just need to test a few settings to see what works best for closing paths and achieving sharp 90 degree corners.
    Manager of Public Relations and Education for KNK USA
    Design Team Member for Team KNK
    Providing the best in KNK education & support at I Love KNK
    Agree Like LOL
    Thanks, Sandy. I guess I'm still a little confused as I believe you told me that that setting in MTC for the KNK Maxx controlled both the offset and trailing blade. Do those 2 work together for all cutters? I think I understand what the trailing blade means - but not positive. I may have mine set too high (offset blade when I have been cutting). I noticed that a set of 60% blades I ordered have a label on the box that says offset .25 - so maybe that's what I should use. I've been setting it higher because I was thinking of the trailing blade setting - gosh - I'm rattling now. LOL
    Carol Bauer
    Designs Sew Fine
    Agree Like LOL
    In KNK Studio, you have the option of setting Overcut and Trailing Blade separately, where Overcut will close a path and Trailing Blade will make corners sharper.
    In MTC and most other cutting software programs, the two settings are combined into Blade Offset.
    Note the Overcut and Trailing Blade settings in KNK Studio use a different scale than MTC thus you would never input either value from KNK Studio into MTC.
    If the recommended setting on the blades you are purchasing is 0.25, then that's what you should be using in MTC! : )
    Agree Like LOL
    Thanks again, Sandy. Ahh - overcut - that's what term I was thinking rather than trailing blade.
    I don't use KNK Studio at all any longer. I only use MTC now. Little by little, things are all starting to make more sense now.
    So if the path in a design doesn't close completely, I would raise the Blade Offset from .25 to maybe .30?
    Carol Bauer
    Designs Sew Fine
    Agree Like LOL
    Yes... exactly!
    Agree Like LOL
