Have been wanting to get the Sizzix Eclips for a long time now for it's ability to do the most intricate cuts and scorelines, but have been waiting for it to be compatible with a design program like MTC. Recently learned that the Eclips is now working with SCAL... I have used and loved all the wonderful features of MTC for several years and really wish to continue using MTC when I get my new Eclips cutter...
No kids, no pets, but will trade husband for Black Cat Cougar. He comes with clothes and construction tools....
http://superpoints.com/refer/rhodajayne Looking for a program like Swagbucks to get Amazon GC? - Superpoints!
I wonder if the Zing plug in could be programmed to do this, since it is software controlled also.
Cutting with Sizzix Eclips
Free MTC Tutorials:
http://groups.yahoo.com/group/MTC_Tuts/
Free MTC Tutorials:
isn't it true too, that the eClips doesn't do print and cut in the right way? While you can do it, what you have to do is keep tweaking your blade start point, then send the laser light around the object to see if it is around the cut (you visually have to watch it trace around), and if it's not correct, then you move your blade start point and do it again, until it's in the correct position.
Just checking ;) I haven't seen one in over a year, but that was how it worked back then, maybe with it running with software it will function a little differently, but when I talked to the reps there, they didn't know.
Monthly Sale: 6 Sweet November Rubber Stamps for $10
I know there are other machines but over here in The Netherlands the Cameo and the Eclips are the only ones available in stores. All other brands are only available through foreign shops, that means a lot of shipping and custom duties to be paid, and questions about warranty.
I would be interested to read more on it! thanks!
http://www.craftedge.com/support/faq/faq_ecal.html#
The print2cut program that is talked about in the video wasn't released, it should be in the new Ecal software.
Free MTC Tutorials:
Free MTC Tutorials:
http://papasuecreative.blogspot.com
Free MTC Tutorials:
Cutting with 18" Cougar, Silhouette SD and yes, I still have one of those "other" machines too!
Free MTC Tutorials:
Import the SVG file into eCal and cut to eClips. This is how I currently use my eClips almost exclusively. I much prefer create my cutting files in MTC, and just use eCal for cutting. The eClips is a very nice, heavy duty cutter, with lots of potential. I am really hoping that we will get an MTC plugin for it so that we can cut directly to it from MTC.
Free MTC Tutorials:
eClips cuts with much more pressure when you need it, such as cutting through .022" chipboard, white on one side, in a single pass. It takes Cameo two passes to cut through this same chipboard. Both machines have a cutting width limitation slightly under 12" when using MTC or eCal. Both have a print and cut option, Cameo with the optical reader, and eClips with laser type registration. Sometimes the optical readers fail, especially on paper that is not white, or if the printing of registration points is not dark enough, etc. The laser type registration does not have these limitations, but you help the machine find the registration marks.
If eClips worked with MTC, I would probably choose it over the Cameo because I don't use print and cut projects much, and I love to cut heavier media. I also like that the eClips will use the Roland blades that also work in my Pazzles, Gazelle, and Cricut Cutters.
Free MTC Tutorials:
Maybe Andy will come with a plugin if we wait patiently *lol*
Free MTC Tutorials:
First getting rid of my CE..... Thank you for all your information!
Free MTC Tutorials:
I assume she meant with Ecal. I'm waiting on the plug-in for MTC.
I recently got an eclips and eSCAL - but half way through cutting it switches itself off, has this ever happened to any of you? its just so weird! it cuts simple things well but suddenly with something more complex (and not that complex, to be honest) it doesnt like it... Has any of you had this before? any tips?
If anyone is pro with eSCAL or SCAL, have you found it easier cutting grouped lines or ungrouped lines? thanks and have a great St Valentines day!! :)
Free MTC Tutorials:
FREE MTC Files
http://creatingcutfiles.blogspot.com
CE for now
Also from an economic standpoint, it is unlikely that sales of MTC will be boosted much if he writes the plug-in. Most of the people here asking for it already have MTC and he would not receive any income for all of his work. Before the Cameo plug-in was available (and even before I had a Cameo) I made a donation and marked it "towards the development of a Cameo plug-in", a little bribe so to speak!
Free MTC Tutorials:
Longview, WA
