Seamless Tiler Programs
MichelleMyBelleMichelleMyBelle Member Posts: 4,625
edited August 2011 in General
Both are free.
years ago I used this program 20/20, it's great for making seamless tiles. You can download it, link below and there is a little tut on how to use it. You can use your own photos to make a tile, say maybe of a pet, flowers etc. or just a small section of your photo.
http://txhartnsoul.150m.com/tutorials/tiles/tiles.html
Here is another great tut, halfway down starts the 20/20 part of the tut. http://www.don-guitar.com/tiletut.html
I have not used the program below.
Second program: http://www.imagelys.com/index.php and Tutorials: http://www.imagelys.com/doc/html/tutorial/index.html
Thought maybe these would be helpful to someone.
The "BUG" has been Devoured by my new Black Cat!!!! Woohoo 6/3/2012 Blog: http://www.michellemybellecreations.com/ Design Team Leader/Support For:: http://www.scrappydew.com/ Affiliate For: Co-owner of:
    that 20/20 program is awesome... just tried it out
  • DianeMarshDianeMarsh Member Posts: 162
    So does this work with any backing paper jpg? I haven't really got into the textures in MTC mainly because I am still struggling with the print and cut with the Gazelle....I am getting close, but not quite close enough.
    Diane.....Southampton.U.K. Www.keepforevercards.blogspot.com
    I'm not sure I understand, why is a seamless background desirable in conjunction with .mtc?
    Thanks!
    Pat
  • SandyMcCSandyMcC Member Posts: 6,849
    edited August 2011
    When you import a texture/pattern to fill your vector image, you want it to be able to repeat that pattern throughout your image without showing a seam.
    Have a look at Deb's thread here:
    http://forum.make-the-cut.com/discussion/18298/#Item_10
    Cutting with KNK Force, Maxx Air, Zing Air
    KNK / MTC Videos: http://bit.ly/1kmAcoO
    I'm not sure I understand, why is a seamless background desirable in conjunction with .mtc? Pat
    Both of these shapes have tiles/texture applied to them. The one on the left is seamless, the one on the right is not. You can see why seamless is better.
    Also, if you print your own digital paper, seamless gives a better result.
    nelda - thanks! Queen of visual helps again.
    This really clarified why seamless is helpful. Thanks so much.
    Pat
    Both are free.
    I downloaded 20/20 to give it a try. I was making these by hand and it was hard because I had to make sure the image lined up correctly when I was done. I was basically dividing the image into 4 equal squares and then sticking each piece in the corresponding corner to get the seamless effect.
  • MichelleMyBelleMichelleMyBelle Member Posts: 4,625
    20/20 is a great little program that is quick and saves you time when you're in a hurry. You can make a tile from just about anything. For those with graphic programs you can use gradients, other filters along with gradients, shapes, PSP tubes, brushes from Photoshop etc. Just play, but be warned they can be addicting, LOL
    You can make tiles within your graphics programs also, but most times I found using this program so much faster. Plus, it has a couple extra features.
